Help - I can’t render anymore
I installed the latest preview version offered this morning.
Now at "Capture" no hot key is predefined and any attempt to set up a new hot key gets ignored.
what can I do?
You can change by Shift + end
again auaaaaa to me :whistling: I always tried it with ctrl (Strg=German) key ![]()
thanks for your help!!
@EGIESTO It should work as well with ctrl/strg and alt. I just checked it and it worked well.
Which version of Enscape and SketchUp are you using?
… now i have noticed that this phenomenon occurs only and as soon as I have opened a 2nd (or more) SkUp instances. Surprisingly this 2nd SkUp instance seems not be touched by the Enscape Hot Key preset then. I think it’s quite normal for most SkUp users to work with multiple SkUp instances at the same time - so how does it look with the other SkUp users?
@EGIESTO Thanks for pointing out that you’re using multiple instances of SketchUp and Enscape simultaneously. We’re aware of this issue.
The first instance of Enscape uses the defined hotkey. The second instance can’t use the already taken hotkey and so on.
Therefor you can’t define as well a already taken hotkey twice.
Maybe we’ll find a solution for it in the future.
… Thanks & good to know
however - does there exist any standard render button anywhere?
@EGIESTO No ![]()
