Since installing Vray 6 hotfix 1 I can no longer drag and drop my textures in the “Bitmap” field of the VrayBitmap map. I have to click the three dots and browse to the texture’s location. Anyone else seeing this?
Thanks for the report. I’ve logged it (internal bug-tracker id: VMAX-12446).
Wait,
You can actually drag & drop textures from explorer to VRay bitmap?
Thanks!
Yup. It’s pretty neat. Or it was, to be more precise.
If you are on a version older than 6 hotfix 1, it should work.
Today’s stable builds 31557 (Chaos) should contain a fix for this. Only one case if the name contains frame numbers like image.0000.png is not yet handled - fix is coming in a few days.
Worked like a charm. Thanks!
