Can't even explain
OK here we go. I am trying to do a quick rendering for work and I keep getting this pixelated mess on the renderings. Modeled in sketchup and exported as a dwg file. Then file linked to viz2007. I have been doing it this way for 2 years and this keeps happening now. It also happened last night on a different rendering. I had rendered it 100 times and everything was fine. I hit render last night and this pixelation happens. WTF.
Please help.
Double Faces maybe ? Try raising your secondary ray bias to 0.001 or 0.002
Thorsten
Second that !
nikki Candelero
Can you tell me where that is located?
Thanks. I changed it several times and still nothing. I will continue playing with it. Thank you all for the fast reponses.
OMG How stupid of me. Apparently you have to extrude the faces in sketchup. If not Viz can’t recognize them as faces. Instead it flips the normals oddly even though I render everything two-sided.
Thanks again for all of the responses.
Also, by default sketchup exports two duplicate sets of geometry. One for the edges and one for the faces. This can cause a lot of coplanar issues.
My solution is not to work with sketchup geometry in max, but to simply snap to it as needed while remodeling everything far more efficiently in Max.
