Cant exclude object from lights
Vantage ignores exclude object setting for vray lights. Also if affect reflections is not checked for a light, the reflected light shows up anyway.
Hi george_chianese1,
Light exclude is currently not supported in Vantage, it is in our TO DO list but cannot say when it will be available. The Affect reflections option works for materials that have Reflection glossiness = 1.0. If the material has value below 1.0 or a texture for glossiness you should probably want to have Affect specular OFF in order to achieve the look you are going for.
Alexander
