I have this batch bake script that’s part of my V-Ray Tuner script but one thing I can’t figure out how to get working is how to switch texture baking on as a MEL command (the dropdown attached). If someone can tell me what the command is, that would be great.
I’m not in front of my machine right now, so I can’t check, but it should be an attribute of the vraySettings node.
Not sure which of the following you need, but here you go:
That will change the selected item in the drop-down menu:
optionMenuGrp -e -sl 2 vrayBakingEngineCtrl;
The following will set the baking render:
setAttr “vraySettings.bakeRender” 1;
This is another setting you may need:
setAttr “vraySettings.sh_export_on” 0;
And these are for the interface - to enable other controls:
attrControlGrp -edit -enable true vrayBakeChannelCtrl;
attrControlGrp -edit -enable true vrayBakeDilationCtrl;
attrControlGrp -edit -enable false vraySphericalHarmonicsOptions;
You can see what happens when you change the selected item in that drop-down menu in vrayCreateCommonGlobalsTab.mel
Hope that helps. Let me know if there is anything else you need.
thanks - that did it.
