I’m having some trouble getting the BakerTool to output UDIM tiles. With the UDIM-toggle disabled, files are written to disk as expected; with the UDIM-toggle enabled, nothing gets output. In addition there are errors in the log (see screenshot).
I’ve attached a simple test-scene and hope someone can tell me whether I’m doing something wrong, or the BakerTool utility is being buggy?
Cheers,
Dan
VRAY_RFE.zip (820 KB)
Hello @Dan_Andersen I noticed that you have posted a similar question in the Solaris/USD page. Could you please clarify whether you need the UDIM Baking in the OBJ or in the STAGE network?
To bake your UDIMs you need to go to the OUT Net > V-Ray Renderer and click on the Bake to Texture to uncover the Bake settings. Then adjust the paths, objects and values as you desire and render: http://ftp.chaosgroup.com/support/scenes/houdini\_2024-04-11\_08-57-44.mp4
Make sure to have the <UDIM> in your output file name.
More information about the Baking process you can find here: V-Ray for Houdini
Hi @Dan_Andersen , the UDIM baking will work correctly in next nigthly build.
Good news, thank you @chakarov !
