We’re simulating sparks in Houdini and rendering them in Maya via alembic in a vrmesh node, but are having trouble getting non-linear motion blur working. They render with curved motion blur in Mantra but once in Maya it’s all straight lines no matter how high we set the geometry samples.
VRay build 26855. Was the sub-frame particle support introduced after that?
Should the particles have velocity baked in for each subframe or does VRay compute the velocity itself based on particle positions on subframes? (we have non-changing particle count/order so that shouldn’t be a problem)
Yeah, that’s not how it is supposed to look. Can you attach the Alembic file for this? It should be working fine, but maybe there is something else going on.
