Can't get DR working with daily build sep 14
Hi All,
I was previously using 45 day trial of Corona 2, until yesterday when I purchased FairSaaS and updated to daily build sep 14.
DR was working fine for me until the update. Now I can’t get it to work. It keeps ‘downloading scene’ then ‘starting’, then ‘parsing scene’ then ‘not working’ and repeat. The error I get is " Cannot contact 3ds Max, trying again …"
I have max/dr/corona logs available if that will help? I’ve done an uninstall / clean install and still no luck…
Any tips?
Looks like your DR nodes need to activate the Corona license, see
https://coronarenderer.freshdesk.com/support/solutions/articles/5000564325-activating-corona-renderer-for-3ds-max
Good Luck
Nope, definitely activated…
Others are reporting problems too… https://forum.corona-renderer.com/ Daily builds version 3
Then yes, the logs would help.
Good Luck
Then you should report it here.
and if there is no stable workaround roll back to stable version - Download | My Chaos
Any DR issues in the newest daily? (20.09)
Thanks for the follow-up.
Sadly, I’ve been a bit too busy with deadlines. Will hopefully give the new daily a test tomorrow…
Didn’t get a chance to test DR with the Sep 20 release.
This was due to another, bigger, issue I was experiencing: I made a scene on one PC (let’s call it AA3) with daily build 14th Sep and set up a batch render with 3DS max. I transferred (via dropbox) this file to another PC (AA2, on the other side of the world) and when trying to do the batch render, 3DS max would crash immediately, every.single.time. No error report, nothing. As soon as I reverted back to Version 2 official release corona, the crashes stopped. This was particularly problematic with the deadline only hours away.
So, from these failed experiments, I don’t think I’ll be using daily builds any more.
Hopefully you’re able to recreate both the DR bug and the Batch render crashes.
Let me know if I can help in any capacity…
@aaouviz
If possible, please try rendering the scene manually and see if it crashes without the batch render being used.
If you can, it would be very useful if you could upload a scene with this problem to us since I can’t reproduce it (never had any similar problems with any dailies or scenes). Thanks!
