I’ve been trying to fix this all day… But can’t seem to find a fix for it.
I’m trying to make a credit card, the Displacement Map worked fine before I tried switching from Cinema 4D’s renderer to Corona. I have set up all the materials from new using the Corona ones and still it won’t show up on the model in the renderview. I am using the Layered Material to put them all together.
Hi Martin. I’m not a C4D user, but for layered materials the same applies to both Max and C4D: displacement only works in the base layer. So put the displacement map in the base layer, and it should work - unless there’s a bug in C4D.
Hi Martin, Can’t really add much more than PROH has already mentioned. Instead, I have created the scene file for you. Note that I included a mask for the lettering to be excluded from the card colour. It should be enough to get you started. Hope that helps.
Yep, that’s it. I also used the default settings in my example. Lowering it will improve the look of displacement when viewed up close but I don’t think that’s the issue here. I’d still try blurring the displacement scale in the material options. At least you’ll be narrowing it down.
