Can't get sunlight system to work.
Hi, I’ve read a lot of older posts regarding similar problems, but I still can’t figure out what I’m doing wrong.
Problem: the changes I make to the sunlight system doesn’t seem to affect the scene. I’m tweeking every control I can find, but when I render the sun is still in zenit. I’m saving my Sunlight System settings as default, but nothing happens.
I’m thinking that there is a ticked box somewhere in the extensive (and parallell) settings of VRay that shouldn’t be ticked, or vice versa. But I can’t find it, and I’ve been looking for hours, tweeking every control I can find, ticking and unticking every possible box… I’m feeling a bit desperate to say the least. Can someone guide me?
Re: Can’t get sunlight system to work.
did u used Sky type in the Gi and Background!
also remeber to turn on the physical camera!
Oh my god.. Ehrm. Problem solved. This is almost too stupid to put up on the forum, but here’s what I did wrong:
I didn’t “place” the sun in the scene after making my adjustments in the Sunlight system panel.
Thanks anyway Leobonilla for you input! Maybe you can help me with my next issue?
I have the default settings exept for having the GI (skylight) set to “none”. I have also disabled shadows under Environment / Background.
Renders during daytime works perfect - they look nice and shadows are displayed properly. However, if I run a render during “nighttime” the scene is still quite luminated instead of beeng completely dark. How do I fix this?
Thanks for helping me out!
if you are not using sky in the GI, decrease the multiplier of the GI lower than 0.3
