Hello. When I try to import render settings from “Import render settings → User” there are no settings to be found. This is deeply frustrating since I’m doing a lot of production shots that all use the same settings.
Please help. Thanks
Please help. Thanks
You should export your settings beforehand (usually) here “C:\Users\<username>\Documents\maya\Presets”. Try this and see if it works out.
