So I’m rendering an image with Adv, saved it to VFB history and then I switched to RT to check something. I then switched back to Adv and tried to load the render settings from the saved image. It didn’t work. Settings were still at default.
On our side everything seems to be working fine.
Wich version of V-Ray and 3dsMax are you currently using?
Does this issue occurs on a spesific scene or on every new one?
Does a spesific setting could not be loaded or all of them?
Does this issue occured only once or you could still reproduce it?
After further testing we managed to reproduce the issue here. This issue was reported as a bug to our system and we will inform update this thread when we have progress on it.
Great, thanks.
