Can't open Asset Tracking
Deleted the ENU folder, and everything works great again. Installing 1.5.1 had no effect. Guess I was just unlucky with some corrupted files…
Hi
This might just be a total coincidence, but I just noticed that I can no longer open up max’s “Asset tracking”. Haven’t really opened it in a while, but it worked the last time and only thing changed is my corona installation. Nothing happens if I access “asset tracking” via the menu nor the shit+t shortcut.
I’ve tried to uninstall 1.5.1 = nothing
Reinstall 1.4 = nothing
Repaired 3ds max 2016 = nothing
Hope someone got an idea before I have to reinstall everything.
Maybe reinstalling everything would be too drastic. I doubt it’s something related to Corona, so may you could try removing Max user data first? https://knowledge.autodesk.com/support/3ds-max/troubleshooting/caas/sfdcarticles/sfdcarticles/Resetting-3ds-Max-3ds-Max-Design.html
I got the same problem after installing 1.5
I fixed it by changing some lines in 3dsmax.ini, but after installing 1.5.1, it happens again.
Maybe something’s wrong with the installer?
Can you specify what lines you changed in 3dsmax.ini file?
I replaced;
ATSPosProto=XXXXXX
ATSColumnPositions=XXXXXX
with
ATSPosProto=100 200 700 350
ATSColumnPositions=175 262 87 87 87
Thanks for info, someone may find it’s useful.
Worked for me thanks.
If you have installed Connecter asset management app, then restoring missing 3ds max asset tracker, is a matter of couple mouse clicks. It’s been a real life saver for me, since that damn AT window goes outside of the screen on a regular basis.
Solution here: https://forums.autodesk.com/t5/3ds-max-forum/asset-tracker-disappeared/td-p/6550247
