I can’t open old files (previous daily build 02-20) with the new daily build. 3dsMax encounters an error :
Fichier: c:\Corona\dependencies\src\maxSdk\2016\include\point3.h
Ligne: 332
Fonction: operator /
Expression: f != 0.0f
Best regards.
Ligne: 332
Best regards.
Hi!
We found this same error (or at least, same error message) earlier this week, so we are looking into it. It would be a great help if you can send us the scene file (private uploader is at Chaos) so we can compare our problem scene with yours. Meantime, you can revert to the previous Daily Build, as the error only happens with the latest.
Thanks!
Tom
(Internal ID=479299762)
(PS, also, could you let us know which version of Max, and for interest which previous version of Corona the scene was created with? Let us know the filename here in this thread once uploaded too, thanks!)
The file was created with the previous daily build (02-20) on Max 2016. I did switch to that version and it’s working well again (appart some artefacts caused by the new sample).
I can’t send you the scene right now because it’s not optmised and very heavy.
Best regards.
Same problem here
im getting this error also… older build was ok, latest 16/03 build not ok.
Same issue here on one of my scenes.
We already have 2 scenes where we are able to reproduce this, and a 3rd one on the way, so it will be fixed ASAP.
If possible, please send your scenes here Chaos and let us know in this thread what were your scene file names. The more reproduction scenes, the better.
Fixed in DB from 2020-04-16. Cheers
