Hello, i have a problem openings my 3dsmax project, it just shows black screen and the only way i can open it is as FBX.
Can someone please convert this 3DS file to FBX?
I have to do this project till tommorow, you can be a life saver
thanks.
LINK TO THE 3DMAX file
http://files.fm/u/wbewtsc
I downloaded and quickly tried few import tricks but to same issue. I was also surprised when 20MB zip unzipped to 130+MB scene that is basically just few primitives ?
Thanks for the try
it is a big architecture scene, i have the file in blender, but it is way back in progress ![]()
I convertet it to FBX to import in 3dsmax and add textures and render it there, but coudnt reopen the file
I dont use blender because it has some bugs in corona, i just dont see some objects when i hit render and the texturing part takes much longer then in MAX
hi.
Merge into new scene and skip all objects starting with “sphere.”(the last couple of objects) don’t know what’s up with those but you can get the rest without any problem.
lacilaci you are a life saver, big thanks to you!!!
