Cant save Multi-Pass-Image
Hey,
We ran into the issue that we wanted to render an animation using TeamRender-Clients and the Take-System in C4D but nothing was saved.
At first it seemed to work so far but after the Main-Take was rendered for some reason no images were saved anymore. It created the folders described in the save path but didnt save files (OEXR format - but I tried other file type and it didnt work either).
Only workaround for now was to do it without the multipass and only saving the final image which will restrict us in comp and is far from ideal.
Seemed very similar to the issue John_Do was describing in the following thread (https://forum.corona-renderer.com/ Multi Pass Psd is not saved after render completion )
