Can't see the objects in rendering buffer.
I am trying to render objects in rhino, and i attached the materials. But it does not show in render buffer. Does anyone know how to solve this problem?
Thank you in advance for your
Hello @jimin_hyon ,
Thank you for the screenshot.
Can you check if changing material to a default Generic material helps? Or if you enable Material Override globally? These tests could help understand if the issue is with the material.
In any case would you mind sharing your file for us to check as well?
If this is possible please open a ticket (request type: Product usage questions or issues) where you can upload it. Make sure to archive the scene with the Pack Project tool (V-Ray > Pack Project tool) and share all the requested information.
Also please share what V-Ray build you are currently using (V-Ray>Help>About V-Ray).
