Can't Unhide
hope someone can help.
I hide a number of models while constructing a large scene. For some reason I can’t seem to unhide them. I have clicked unhide--select---all but no luck *only one model reappeared".
When I render the file, however, the models appear. That is fine, but I can’t edit them nor replace them.
Anyone got any ideas?
Cheers…Scotty
Re: Can’t Unhide
It’s not a bug, it’s the way sketchup works. If you hide something inside a group, the only way to unhide it is to open the group and THEN do the unhide command.
There are ruby scripts that can unhide everything (even inside groups), so do a google search for that.
If not, use the outliner to dig through all the groups and find all the hidden things.
Re: Can’t Unhide
Fantastic. Thanks so much for the heads up!
Cheers…Scotty
