I get that I have to output vds for vray top render fluids but how about simple output geo from bifrost? Isn’t there a way to render the outputtet geo with a vray shader?
you need to convert the output from BF to geo or use USD directly.
There’s a define_usd_mesh in the latest bifrost 2.4.0.0. If you place it after the bifrost mesh and then pipe it in a usd stage (f.e. with an add_to_stage node in bifrost) - you should be able to render it with V-Ray.
