+1
Thanks a bunch, your upvotes will be forwarded!
+1
@AmandaPEP - Added your vote. Thanks.
Yes please, it would be most helpful.
Sure!
+1
Thanks!
Upvoting. For simple studies, plain white background is so much helpful.
+1
Thank you all! Your upvotes will be forwarded.
+1
Thanks!!!
Thank you. ![]()
+1 for integrated alpha transparency in png files. The problem with the material ID is that you don’t get an accurate edge fade. So we get this burn effect on the edges.
if you adjust the depth map setting in the capture tab you get a perfect b&w alpha image.
Definitely +1000 votes from me, that would be great when dealing with objects.
Forwarding your votes as always, muchas gracias. ![]()
png output with transparent background would be super useful
Forwarded, thanks!
absolutely CRUCIAL this functionality for diagrams and most architectural production work. without it we’re sticking to Vray. seems easy to implement so would be glad to see this asap integrated
and a shadow catcher ground plane would be amazing if possible, meaning a transparent background but option to not have transparency where the shadows hit the ground. (as vray wrapper material as shadow catcher)
