I would like to create a carshader with flakes / sparkle in it.
I tried several versions, from noise, to sparkle maps, bitmaps and normal maps, but not one of the shader gives me the result I am looking for.
would someone like to help me and work it out ?
appreciate every little help, suggestion and hint.
I tried several versions from posted materials on vray-materials.de
All the flake or sparkle versions I found work with a bump or normal map.
For some reason, it works on a small object like a teapot, but on the car I couldn’t get the right look.
Tiling issues, sometimes it burnes out… and some shaders just use low samples to prodcue kind of flakes - but so you can’t really control the size - it’s just random.
Hmm.. I would love to work it out… but all my tries so far, didn’t look good - or better, it looked terrible…
I will try the one you have linked to, and post the result on a simple geometry…
if you cant get it right, that means probably the scale of the texture in world space is off on your actual model. Further your model must have some form of uv’s. Or it can be generated by 3d noise. Either way, if you would have a custom shader such as mr carpaint shader it would follow the same principal more or less.
I did not find any of the shaders from that site worked too well for me either - at least not consistently.
I would suggest creating a sparkle/fleck map and using that to mix in a mirror-like material into a carpaint type base material using a VrayBlend mat. That way it will react to light more realistically, but you have to use realistic lighting approaches (HDRI Domes, area lights and/or reflector planes etc.) It did not work as well with Max lights, but I don’t usually use that approach.
@Dmitry:
I checked of course the mapping, I also tried different UVW maps, as example the flakes on map channel 2, etc… but couldn’t really find a good way to get the specific look.
@Brett:
thx, I tried a VrayBlend with a base shader and on top of it with the flake reflection.
result was very bad…
I also thought, maybe it works like that:
The sparkles should be the reflective part… so I created a fall off map, and used only in the highlights a speckle map… uff.. but… again, I was defeated by myself…
after trieng a lot of different versions.. I thought it’s time to post for help…
I will try and dig up the material I used before, but I don’t think it was much better than what you have there really. Hopefully one of the real material experts can chip in on it.
Here are two renders of the one I had done. This is using a variation of the sample scene that I use, so it’s not quite the same lighting setup. It’s just an HDRI in a vray dome light though, nothing fancy, just different.
This has two flake layers using the same fleck map, just offset slightly for one. The one has a blue tinted reflection colour, the other is almost white, but otherwise it’s basically as I described before.
Below that is a snap of a metallic car hood that I used for reference. It’s sitting in a more contrasty lighting environment. A bit of Photoshop work would match them even better, but I think I got close enough for what I needed.
I would have to say that it would be nearly impossible to do flakes like that using conventional anti-aliasing and filtering methods. These methods are designed to smooth out and interpolate pixels.
What seems to be pretty clear to me, is you may need to use a multi pass approach. Where you will separate base coat, flakes, and shine with passes, and render the flakes without antialiasing and filtering, then composite them via special mattes etc.
This seems to me a logical way of doing a really advanced car paint.
Thank you for all your participation, that’s really awesome.
@Vlad & Brett:
would be cool if you could post your sample mats, so I can run more tests.
@jacksc02:
I agree, the UVW’s have to be nailed down first… I was thinking to unrwap a specific car, completly, every single part in order to get a nice uvw template. The only bad side is, that if you texture the whole care with the flakes and spread it out nicely, you do have to make that very time consuming work on every new car.
to avoid that, I was thinking to get a kind of procedural shader - well, especially for the flakes.
@Dmitry:
hmm, really nice idea.. the only question is how you would like to start doing that and how you would like to make the composition ?
It’s not as easy to get this specifc look, and all knowledge and tricks must put together in order to get a real master piece.
THANK YOU ALL for your great ideas, comments and suggestions,
I really appreciate that much,
the flakes are not really to control, when used with low sample settings and glossy reflections…
more or less the shader on vray-materials is a fake, maybe usable as a christmas glitter shader on a christmas sphere - I guess for that it’s perfect but not really to use for a car body.
I will keep going and make more tests…
@vlado:
did you already get the chance to get the shader you’ve mentioned earlier ?
Nope, Peter is away in Germany still; I’ve emailed him to send it when he has time.
Anyways, there are two types of car paint normally. The regular car paint, which is some metallic particles sprinkled over a regular paint; and “pearl” car paint which consists of small reflective spheres of different colors mixed together and covered with transparent coating - this may give some clues for simulating it
thx vlado and everybody else for participating and cracking this nut.
today I didn’t have time to make more tests. below my last try from yesterday night.
hmm,m the transparent coating is maybe a great idea.. I will run some more tests and I’lll keep you posted. Ohh yeah, - hopefully Peter will be back soon from Germany.
If you think about the composition of car paint it might help you create the material. Paints have a undercoat which is different depending on the top colour, then the base colour is applied. If you want to have a sparkle effect that would be applied in the clear coat which is the bit that makes the car shine. Some metal flakes are applied in the base coat. Have you tried using a composite material with a base colour and then a falloff map for the clear coat with the speckle in or I remeber people using a shellac map before.
I did this one with cellular maps in the anisotropy and anisotropy rotation slots, looked cool on the sphere but when I put it on a car model it didn’t look too great, didn’t have much time to play after that. Might be worth investigating more though.
