Carpaint 2material crashes when rendering animation - VRAY GPU
It appears that carpaint 2 material will crash on frame 2 of any animation (frame 1, or still frames render fine). Using the latest version of VRAY GPU.
[0h 0m 21.5s] C:\CI\cgrepo\vraysdk\samples\vray_plugins\rt_priva te\rt_opencl_(1622) : CUDA error 700
[0h 0m 21.5s] C:\CI\cgrepo\vraysdk\samples\vray_plugins\rt_priva te\rt_opencl_(1556) : CUDA error 700
[0h 0m 21.9s] [MemoryManagerGpu::releaseUnmappedMemoryFromInstanc e] 700: Could not release device buffer
I’ve attached a sample scene, thanks!
Carpaint Crash.zip (75.1 KB)
Hello @scott_canuel ,
Thank you for your report. Upon testing I managed to reproduce the crash on my end. I have now reported this in internal system (bug ID: VC4D-1118 ) and I will let you know as soon as we have any updates on the matter. Thank you for your understanding.
Hi @scott_canuel ,
This issue was fixed and the fix can be found in the latest stable build. You can download it from here:
