hi..discuss carpet materials in enscape 3.0
It is not working effectively…it is more like grass material than carpet…(grass for low vesion 2.8)…
Is it possible to do the same ?.. ;( ;( ;(
Hey @Thanh_Chuong , at the moment the results attached below are not possible in Enscape - we’re working on improving our carpet material further. In the meantime, to help with the areas where the carpet is not applied, you can use a separate plane, apply the same carpet material instead there, and put it slightly below the floor that only the carpet appears through but not the plane. I hope you get what I mean! If not, let me know and I’ll attach an example.
Also, the ability to have grass/carpet on vertical surfaces is also on our agenda filed as a feature request. I will forward all of your feedback accordingly.
I hope it will be imporved with new update…if there are picture to guide what you say, great ![]()
I put it slightly below the floor, It works, but it’s not practical.
Also i think the aspect could be much better like the FUR in V-Ray
I sometimes use the Enscape Rug assets which are a bit better.
+1 +1 +1
Please update next a better carpet. Thank you.
i just guess the empty edge is just prepared by developer for the rotate carpet like picture below (in every edge of carpet) but it is not yet implemented in this version
i hope that ready in the next update.
@jwal485 The rugs in the assets are ugly. Só We need to be abble to make them.
In the picture above i saw a collision here sandal with carpet am i right? i dont know in the future update Enscape will have this. When we have a ball in the grass, so the grass will not grow above the ball right? ![]()
Can we have a collision effect in Enscape? @Demian_Gutberlet it is usefull as an example when we have i plant in front of the wall and the leaf can be seen behind wall too. But if the Enscape have a collision i hope this leaf of the plant can cut automatically.
Me too … i hope it improves
Hi!
I have been doing some digging and found the reason for strange shag like carpet. This image profile located in C:\Users\xxxxxxx\AppData\Local\Programs\Enscape\Renderer\SystemData\Textures\Enscape\Common dictates the texture mapping of carpet. I was wondering if anyone knows how the mapping works and can mimic it with a cut pile profile.
The same logic applies to the enscape grass, and when I changed the image, the grass was hugely improved.
i always render my grass with carpet material type.. lol the view of my grass more better rather than i set it with grass type ![]()
Yes it is worst but i think it is still on progress the dev is still developing for the edge of the carpet. i saw another render engine had a good view of carpet edge lol you can google it. i didnt use carpet material again. i only use a flat JPEG material for the carpet. But i used this capert material for my grass lol
