Carriben - Resort
Hi mates!
This time i came up with a nice summer collab, i hope you like the refreshing renders!!
more here : https://www.instagram.com/alm_estudio/
Thanks!
Great atmosphere, I wish I could be there. :smiley:
Other than that, looking from a technical perspective:
  • if it was rendered with Corona 10, it would mean that the scene uses two new features: caustics rendering better in high resolutions and having the camera half submerged in water
  • is this some kind of photomontage? (I mean the edge of the water surface with bubbles) https://forum.corona-renderer.com/index.php?action=dlattach;topic=40722.0;attach=186700;image
  • in the same picture, what is this weird pattern that looks like white strings more or less in the lower-center of the image?
Thanks a lot!
Actually this one is still corona 9, i will update to C10 asap!!
Yeah the water line and bubbles are a part of the photocomposition but is just the water line, the underwater pattern and casutics are directly from frame buffer. Those weird lines are part of the caustics, maybe the new C10 will improve it, i need to give a try.
Thanks for your answers! I would be curious of the caustics improvements (they should definitely render sharper and brighter in high-res) and you could use the camera physical size option for that half-underwater shot. :smiley:
https://support.chaos.com/hc/en-us/articles/11905001704977-New-Volume-Resolving-in-Corona-10
What!!! is exactly the improvements i was looking for in this scene!! thanks a lot for pointing it out, i will give a try once i donwload the new corona version.
Thanks again!
Hah, I just thought about those things when I saw the images. :smiley:
