Casa Gaspar
Hey Guys,
First post, been lurking here for around a week although i signed up a little while ago. I had been hearing great things about Corona so decided to give it a try myself. I had this project that i had put together with Vray, just a personal piece and i thought it was perfect to give Corona a run. Its a private house called Casa Gaspar in southern Spain by architect Alberto Campo Beaza. Apologies for the lack of externals, i tried the corona scatter but it was too simple to convert my Forest Pack foliage scattering and i haven’t updated my license for that yet.
I love coronas GI quality and the relative speed to quality ratio, i had to work much harder to achieve similar with Vray. It was seriously enjoyable and addictive to work with and felt much more free to create for some reason. Planning to stick with Corona and looking forward to see how it progresses!
I did have some niggles that i experienced and things that i missed from my Vray workflow, namely Vrays directional AO bias for nice masks for drips would have been handy when creating the white render material. I also had a problem with getting light to cast through an excluded object (i.e. a corona light inside a diffuser not casting through the excluded lamp diffuser that was set up with a Corona light material just for self illumination). This is probably more user error as it was my first bash with corona. Other than those its been a pleasure working with Corona.
Some simple post production, nothing drastic though. The renders straight out were great and only did some minor bits and pieces like slight colour adjustments etc. There is still some noise kicking about, one or two could maybe have had longer in the oven. Especially the close up shot of the Glass pear, i had to use noise reduction to help clear some, but i only rendered it for an hour.
Any way, hope you like them. :smiley:
Very big potential i see. There is too much CA imho. You can try to squeeze little bit more from this scene with better composition and camera angles. Try to check some arch. photographyv :smiley:
I was trying a different way of doing CA than I usually would go about it. Maybe over did it a little.
Composition is one of those things where everyday is a school day and there is always somewhere to improve, I really should try and squeeze more time to look at more photography. Time is tight, you know how it is. Out of curiosity what would you do differently?
Thanks for the constructive criticism, really appreciate you taking the time. :smiley:
Very nice work. What cpu do you use, and how long did courtyard01 take, and how long did interior01 take?
Thanks for sharing!
Thanks BKE.
Rendered on a single I7 930.
  • Courtyard 01 I left overnight. As it was my first full resolution render i didnt have a time in mind so set it for 7 hours and when I got up in the morning it was fine. cant remember the passes off hand. I think around 50 but I will double check when I get home. Courtyard 1 and 2 were rendered PT+PT
  • Interior 01 took around 3 or 4 hours if I remember right. Interiors were rendered with PT+HD Cache.
Very nice! I appreciate you passing that along!
Sincerely,
Brian
