Casio watch wip
Hi
Recently I made a Casio watch, now I want to visualize them in the environment. Test render.
only 4 passes per hour? what PT samples do you use?
60 samples)) Just DOF were artifacts and I decided to pick up samples. I left the renderer for the night, so the time is not critical.
and I use Bidir/VCM configuration
Thank you, I will consider for the future. Just for the Russian is not very much information about the corona render
Что, в гугле забанен? http://cgpolymax.blogspot.ru/p/corona-renderer-faq.html
Я и ещё многие и без русского хелпа разобрались.
Check back later. Now my computer is chugging along on the renderer.
I recently drawn on Watch the studio.
Ну это понятно) Да просто и времени особо нету искать все. Для этого и открыл вип, чтобы опыт черпать.
Thank you so much for that explanation, can you explain what the HD cache samples and how they contribute to AA/DOF and flickering during animation
Made another render. Yes, of course a long time)), but there are artifacts on the Blur. Now I do render, with settings that advised Rawalanche. Still, I reduced the resolution a bit. For 15 minutes 30 passes. Wait.
Oh, yes, in the scene, a source of light - corona sun and corona sky in the environment.
Disabled Reflect the sun, added a light.
The first picture with the usual sun and light. The second with HDRI.
oh yeah, I got hdri and sun. I just need to try hdri. But in the post, I think it is better not to yellow, because the grass is worse.
I make the color correction, from source raw in lightroom.
here are the raw image
HDRI. 2 variants post processing.
