Dear Friends
Is anybody know or can help to bake a caustics from water into a textures through baking Corona 11?
As i notices there is a dots but not a real water reflection. During a rendering this dots become more transparent and light but does not transforms into a real caustic reflection.
PS. Caustics working well in interactive and production rendering.
Reflections/ refractions can’t be baked to texture, since they are view angle dependant. I believe the same applies to the caustics, although i’m not entirely sure about that.
Indeed, both phenomena are “view” dependent. Tho for second, faking VFX is easy using animated ‘gobo light’ texture, since human brain can’t recognize ‘correct’ pattern (voronoi does the trick).
Hmm, caustics should definitely be made to work with baking. They depend on light position/direction, viewing angle isn’t really part of how caustics are produced in an otherwise static scene, just like GI.
Generally, I would not have high expectations with texture baking, but it seems that the available render elements for baking in Corona give mostly the beauty (whole lighting information, including caustics), for the selected objects with the specified UV map, which I think can be used, at least to some degree, for baking.
I would go with the trial and error approach.
You can have a look at the screenshot and scene attached. CoronaCausticsBake.max (828 KB)
