Caustics not working
I’ve followed the standard tutorial on creating caustics with Corona, but they don’t seem to render out at all (using 3 hotfix1 at the moment). We need these caustics as part of the main render, so switching to PPM just to render them (as other tutorials say) isn’t a workable solution.
I’ve attached the test scene, but the attached render shows what result I am getting.
Any ideas?
Thanks.
causticTesA.zip (6.23 MB)
  1. Your light source is tiny, so it’s extremely hard to sample
  2. You are using an IES light - I checked that disabling it helps render caustics
  3. Remember that increasing MSI in the Performance tab will increase caustics intensity
    Other than that I can only recommend waiting for the daily build with new caustics included. :smiley:
Btw: 1583 animation layers in your scene, see
https://forum.corona-renderer.com/ HELP - file size problem #msg106638
Good Luck
