Caustics pass crash
I am getting pretty frequent crashing when using caustics pass. A bug report is attached, hopefully, it helps to clarify. The crash is every 2nd render try.
Daniel
_BugReport.txt (935 KB)
Hi Daniel, Sorry to hear this. Are you a Win user at all? If so, can you also share the minidump .dmp file with us? It’s also located where the bug reports are. Could you also supply a test scene where you’re able to reproduce this? What version of Corona and C4D are you running as well? Thanks in advance
