caustics photon map
Does the caustics photon map depend on resolution? Or is it like light cache…you can calculate at a lower res, save the map, then use the saved map on a higher res file? Thanks!
Its resolution independant AFAIK
Yep, the photon maps do not depend on the resolution.
