I have problem with caustics that wont show if i add just one box-plane for environment. All the time i was do this with alpha channel but in this case I want better integrated image with background because lot of trees, leaves in the scene etc.
Also box is excluded from daylight (vray sun)
Here is a scene with one box-plane that simulate environment and caustics is no visible:
This is solved for the service pack, but in the meantime you can use a VRayOverrideMtl material with the base material to be the background, and the other materials - perfectly transparent.
You are almost there… now just make the color in the VRayColor texture black instead of white… (remember that white is full opaque, and black is full transparent).
