When piping a map through CoronaColorCorrect (CCC) and using it in the bump slot, bump is lost if brightness is left unchanged at default = 0.
Repro:
- Open scene, open SME
- Render IR → bump ok
- Plug CCC directly into bump slot → bump gone
- Pipe CCC output through CoronaBumpConverter (CBC) → bump there, but less intense
- Plug CCC directly into bump slot again → bump gone
- Change “Brightness” in CCC to any value <>0 → bump there
And a bonus glitch:
- Plug CoronaWire map into bump → bump ok
- Pipe CoronaWire output through CBC → bump gone (I guess it’s the “Falloff” needed for use as bump)
Good Luck
Max2016 | Corona DB v4
Corona_BumpIssues.7z (281 KB)
