We’re working exclusively with Photoshop in our studio here and I was wondering how often Cebas PSD-Manager is used in similar circumstances? It seems very nice from what I see and could potentially cut down times for post since the first half hour after a rendering is finished usually consists of getting some (not all) of the output files into Photoshop. We don’t use a “traditional” compositing workflow where we rebuild the image from render elements but rather we take the beauty pass and then do stuff with it with the different passes like spec/refl etc. Is PSD-Manager useful for that workflow, too?
Baically I want to hear some opinions of people using it, how you guys use it, what you find good and bad about it.
I use it and I would highly recommend it. With the progressive render, it has been an issue because it’s not working with masks, yet; I heard that they are working on something. Really, I couldn’t live without it.
Being a PSDM user (and beta tester) for years, I can do nothing but recommend you to ask Daniel Schmidt (PSDM dev) for a trial - one month with unlimited features is generally enough to see the potential of this tool in your daily work.
Like Bobby, we could hardly live/work without !
To give a piece of answer about your “what’s good / bad in it”, my 2 cents:
GOOD
- wide choice of output options (REs, Scene Layers, Named Selection Sets, ObjIDs, MatIDs, Separated Object Output) and modes (channels, layers as render cut-outs / luminance matte / alpha matte)
- easy to use
- automatic switching to PSB if PSD file is too big (above 2Go AFAIR), useful for very hires outputs - or you can simply always switch to PSB, up to you
- choice between 8 / 16 / 32 bpc, to match everyone’s workflow
- full VRay support (gamma correction and VFB Color Corrections baked or as PS adjustments layers, plus per RE)
- unlimited rendernodes with one UI license
- price … it’s very quickly profitable
BAD
- to be honest, I don’t see one for now … will have to think about it, and discuss that with my coworkers !
I kind of heard about it several times in the past but there was stuff like no PSB support (we work in the print industry, so basically we don’t even do PSD anymore :P) and a kind of “old”/“legacy” look to it which kept me from using it. So you say it is definitely up to date and on par with todays stuff? Progressive not working is not that problematic for us since our final renderings are mostly bucket renderings.
I don’t quite get the “normal” trial version of it though. Is it fully featured? Time limited?
But wait : when you say half an hour to get the output files into photoshop… you don’t mean just bring them in separate layers right? This should take a few seconds.
Admittedly this was the hardest one to date. 25k px 16bit floating point image. Bringing in all the layers, setting the blendmodes etc took nearly half an hour
I believe most don’t do a full “back to beauty” compositing. Personally I think, starting from the beauty and subtracting lets say reflections and then adding tweaked reflections back on top is a very useful technique. Lets you focus on what you need to change and simplifies things.
PSB support is new in psd-manager 4.0 and it will automatically switch to it when needed. However if you know you will exceed the limits of PSD files set it to PSB upfront and it will save faster. psd-manager writes the whole image on the fly as the data is generated - that means it doesn’t store an extra image copy in memory - so it will never run out of RAM.
Not sure what you mean with “old”/“legacy” look? - it looks like a 3ds max plugin - not like Kai’s Power Tools (nothing against Kai really, great guy). I try to keep the UI clean and not overload it with options. Some things like entering the Object-IDs in a text field like “1-100, 120-150” may look legacy at first sight - but saves a lot of time, UI space and is simply functional. Try the same with MultiMattes and see how long you click. psd-manager knows which IDs are present in the image and creates mattes just for those. No empty layers.
Progressive mode IS supported - you can save image and render elements, color correction adjustment layer etc. as usual. Just the psd-manager built-in mask generation tools need bucket mode - that is because V-ray provides no deep data in progressive mode. Using the mask generation tools within psd-manager can save memory since the number of mattes does not influence the amount of RAM it needs. So 10 or 1000 masks makes no difference to the amount of RAM required. Writing the image will just take longer. Might be interesting for your high resolutions.
Trial on the psd-manager website is resolution limited (2000 x 2000) and watermarked. I sent you a private message so you can test higher resolutions and PSB support if you need.
Wow, that’s really nice of you! I’ll definitely try it for the next project or two and let you know my thoughts. For that price if it does what it advertises properly there’s a very good chance we’d buy it I think! Replied to your PM.
Edit:
Does PSD-Manager work with resumed renderings (the new 3.5 feature)?
Also: dans are you in contact with RebusFarm to get PSD Manager supported there? Would make sense from a customer PoV.
Resumable rendering workflow in general does work with psd-manager. However, V-Ray doesn’t correctly resume the G-Buffer (deep data) - the V-ray documentation mentions deep data not being resumed in bucket mode. So render elements etc. will export correctly. psd-manager generated mask layers will just show the buckets that were rendered after the render was continued.
Do they support single frame render using V-Ray DR for high resolutions? In the past the problem was that if these render services try to render in stripes then they can not stitch the multi-layer PSD files together. I will contact them what the status is on that.
First of all thanks for the extended trial. We bought it :-).
I noticed though (I am not completely done with my tests yet) that it seems that PSD-Manager won’t work AT ALL when “resumable rendering” is ticked, no matter if it is rendered in one go or not. As I disabled it, it worked fine. This was through Backburner though. And I cannot completely rule out a licensing issue there. Have to test more.
We had LOTS of issues with licensing but in the end that was due to the stupid windows firewall turning itself on on every restart. Duh. (For anyone with similar problems: Disable the Windows Firewall Service completely, should stay off then…)
As soon as I figured out the windows firewall was blocking it it seemed to work but somehow my setup with the password for the license got…messed up? I think I have it working now. To be completely honest personally I would like it MUCH more if we had a online-licensing system where say you have to login every x Days to “renew” the license. But that may be just personal preference.
Thanks again for all your answers, especially dans.
Edit:
They still seem to render that way. It would be gold though if you guys could figure out a way to make it work.
A licensing issue is unlikely as network rendering never requires a license. Maybe you tried to render a scene that was saved with the Trial version or still had the Trial installed on the slaves? Scenes created using the Trial need to be opened once using the full version, check psd-manager settings in UI and saved again. Maybe you can send me some steps you used to test this and a simple scene file to mail@daniel-schmidt.biz.
If you used the separate licensing service installer that I sent you, then it would have added an exception to the Windows firewall. You can also run the installer now, it will not affect your license. Installing the license service via product manager doesn’t do this automatically. This will be changed. Sincee you wer in contact with someone else regarding this, I will check back with cebas.
Thank you for using psd-manager.
I have raised the priority for this - it is on the roadmap to provide a tool to stitch PSDs. If you want to use a network rendering service, always let the service provider know which plugins you want supported.
If I am not mistaken, masks from layers will not work with progressive, correct? I thought I was told that it is in the workings. Now, the elements are created when you Stop the progressive render, which is awesome.
psd-manager masking tools currently require deep data, which V-ray unfortunately provides only in bucket mode. However, let me repeat myself from the cebas forum: It’s on top of my wishlist - I’m working on something, if there is something ready to test I will let you know - not promising anything.
If you see something worth improving - please report it - don’t assume others did or feel the same. I’m aware of one specific case that could slow things down a lot in the past: - using V-Ray Curves color correction + many Render Cutout mode layers. There have been some improvements for this case in 3.2.2. Reason was that applying Curves adjustment takes V-ray a lot longer then the other corrections.
Using the new adjustment layer for V-Ray color corrections in psd-manager 4 also solves this special case.
If you don’t render animations and have a large SSD you can try to turn PSD file compression off to test if this speeds things up for you. Files will get much larger of course - so please set format to .PSB beforehand. You will not loose data if you use PSD, but internally psd-manager will first try PSD and if the file gets over 2 gigabytes it will start over with PSB - so that would skew time measurements. In 3ds max simply use this line of script to turn file compression off (assumes psd-manager is first render effect): (getEffect(1)).compression = off or (getEffect(1)).compression = on to turn compression back on.
I would be intererested in speedtest results - you can send them to mail@daniel-schmidt.biz If some users think this is useful I will add it to the UI. Photoshop has a similar option to turn file compression off in preferences.
Using minimize filesize in the psd-manager advanced options can also help a little.
I have had a quick go of the demo and the masking by layer alone is awesome.
Am curious how/if psd manager handles updates to the psd files.
I do a render and it assembles my psd.
I start to grade and duplicate and mask and group.
Get a change from a client and re-render and psd manager generates a new psd and I have to either start again or copy everything to my psd.
Not a problem if I have 1 file but if I have 50 this becomes a real issue.
I understand that this is a flaw with photoshop itself but I would love an xref type workflow.
To combat this we are writing a sync script for photoshop that update a psd with the latest renders in a folder.
It will look at say v02 folder and as the files always have the same name (vray lighting etc) and the layers in the psd are named after the files it goes through and replaces each layer with the file from the folder.
It kind of works, still bugs and easy to break but I can really see the potential in it.
Would be great if it was built into something as stable and well developed as psd manager.
‘Updating’ the PSD file is on the roadmap. If you have a PSD setup in psd-manager that already matches the way you would build it in Photoshop, then swapping things out between 2 PSDs isn’t that difficult. Atleast that was the feedback I got from some of the Beta testers, but there are lot of different working styles. If you have to do it for many files, then each step matters of course. Simplifying such workflows is exactly my kind of thing and I’m no stranger to Photoshop plugins and scripts. Somehow I never run out of things to add or improve.
BTW, for the early adopters - 3ds max 2018 support is in good shape - should be out next month as a free update.
