Centralised Admin-Controlled Installer/Pane for network installs (like Pulze RM)
Hi devs,
Would you consider a central admin installer/panel that will detect all corona installs on your network and allow you to update them all in a single click, like Pulze RM does? You can run the analytics audit first to see which machines have which versions installed, and then simply deploy a silent update across your whole “pool” in one click. It’s pretty awesome, to be honest. Even better, this could be a standalone admin Corona control panel or something… and you could do things like deploy the material library across your network, update shared paths, deploy a daily build alongside the main build on whichever machines you specify, manage users and licenses etc…
AKA pls bring power to admins/centralised control :smiley:
Cheers!
