Certain objects failing to toon render
I’m not really clear what the Toon node is or how it works. It’s not a shader, and it doesn’t appear to be a set. So I’d assume then that anything visible in the scene with it activated should render with it (absent any exclusion sets, which I don’t have).
I’m not seeing that and I’ve had a few instances of things simply not rendering in the toon pass despite being visible and with no other factors apparently in play.
Can anyone advise what’s going on?
Hm, this may in fact have been down to lack of shading assignment on a render layer…
If you still have issues with you could share your scene with us so we could take a look.
