CGAxis materials importing with wrong normal maps
Hi Forum,
I have a question on normal maps. Every time I import CGAxis materials or create materials with Great Summit Texture Manager the normals come in with a cyan hue. I can fix this easily by setting colour space to ‘RAW’. Is there a way to set this permanent so I don’t have to do this all the time?
I don’t know those materials and what color profile those normal maps have. But usually they need to be loaded with the “linear” profile.
Can you share a screenshot?
Hi Lollolo, here you go :+1:
Are you remembering to add the Corona Normal node? Looks Like you’re just adding the normal map straight into the bump slot? Normal should always be set to linear. RAW is more of a redshift naming convention
