CGeometry_ZDepth Not Saving in CXR Format
I experienced a bug saving my Z Depth pass. When saving CXR format from Max, the z depth pass falls out of the file, not present in CIE. Also not present when auto saving individual passes to CXR from batch render. I have to save this individual pass out from the Corona VFB inside Max.
I haven’t tested other CGeometry passes, but I can say for certain there’s an issue with CXR including z depth. It has occurred on files saved from the 9-15-2017 (first 1.7 daily I tested on my office workstations) daily to RC1.
Hi, we have changed how alpha (and other single-channel data, incl. zdepth) are being stored in CXR. Probably in next RC the editor will be adjusted to reflect this new data layout and it should work as before.
I will be glad if you will be able to test it. :slight_smile:
Fixed in 1.7 RC3
