I am looking for away to make a chain link fence, anyone have ideas on how to do this in Vray? without having to make all the geometry?
Cheap quick way - create a plane and add a chain-link map with an opacity map. Max’s and viz’s architectural textures pack come with a chain-link material with a seperate alpha map.
If you turn of bitmap filtering for the opacity map it should render a bit faster.
You can find some very good fence Materials here:
Just have a look in the “architectual” sector. There you will find a nice material called “iron net”.
Mirko
Dmitri (the lovely man) wrote a tutorial about doing chain mail a while back and the same technique should work for this - http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=10951&highlight=chain+mail
There was a post at evermotion about doing a chain link fence using some image based script. It’s in the free section.
