Chamfering with 3dsmax9 PB3 (productivity booster rev3)
OMG tired of deinstalling this shite! Every time I try to chamfer several simple edges - it just crash!
Over my simple debugger I caught this line just right before max crash
[1812] MNFace::VertIndex(127,-1): No match.
Any ideas what’s that ?
:evil: :evil: :evil:
happens to me as well with max 9, not only chamfer, but crossing 2sidedmaterial also crash. sometimes moving vertex also crash. i gave up and save alot..
I just tried chamfering a box (editable poly) and it worked fine for me.
Max9 PB Rev3
What sort of mesh were you trying it on?
Just plain poly mesh. Several groups of edges give an error.
Try this :smile:
http://www.furk.net/grill\_crash\_36495.rar.html
Select that edges and try to chamfer 'em…
P.S. I’m so damn maad. Coz of this shite I can’t complete my Chevrolet Camaro concept model :frowning: Love Transformers and wanna build this babe :smile:
Slightly off topic I know, but how do you make your 3ds max gui to be black?
In this case it looks like the default dark-scheme. Just goto the Theme Switcher via the customize menu and select the dark scheme
Thorsten
Ok, found a work around for you. Dont know WHY it work but it does.
Select the mesh, switch from single viewport to quad viewports (press the maximum viewport button… bottom right hand corner) then press it again to go back to a single viewport, then your chamfer will work :shock:
Btw i just downloaded ure scene and it crash when i try to chamfer any edge…but it crash when you work in poly mode…
I converted your poly in mesh and i can chamfer as i want your object
try it!!!
after you can come back in a poly object
DaForce
Still DaSame :frowning:
BiTcH
DaProblem is in fact that I hate mesh! :smile:
P.S. Any ideas ? Coz I’m goint to uninstall that shite. Never got this issue with plain max9
weird works perfectly here.
Just got from the one maximised viewport back to 4 viewports then back to 1 again and I can chamfer without any problems!!
talking about power booleans or polyboost here? might be a dumb question, but i was considering buying the polyboost, but since i read this post i am not so sure…
Martin
“productivity booster” revision 3
its like a service pack.
i think u can’t uninstall it …eheheh
i hate mesh too but when it waorks …i like it :smile:
Maybe it’s because x64 version ?
Tried converting to mesh and then back to poly… Same shite :frowning:
Uninstalling max9 pb3 :frowning: Damn :frowning:
paul just chamfer your object under mesh mode and after get back to poly
i just did it it works fine too
It didn’t work for me :frowning:
btw da force is right if u maximize ure viewport in user mode if think it works…you can chamfer all your edge with poly
it works for me too…
I can chamfer all edges, but that group, that is selected on picture I upped here…
Anyways - now it works :smile: Max9 without any sp or pb :smile: Kewl!
Btw - Vray is absent too.
P.S. Will install SP2… Will see what’s gonna happen.
P.P.S. SP2 - works. Trying PB3.
u could have try with that file under pb3…
http://www.furk.net/grill\_nocrash2\_55122.rar.html
My PB3 package is broken. Somehow…
