Hi guys, Im using the Corona v7.2.
If I change the curves of Fallof map during the render, the 3dsmax crashes.
Same for other curves in other maps.
Enable dev/experimental rollout and make sure that “Lock 3ds max during rendering” checkbox is ticked in it - that’ll solve your problem.
That’s not a very useful solution. :
But I think it’s a known issue. Same with editing bitmaps while rendering.
dailies should no longer do that ![]()
