Is there any way to edit the default size (height) of the VRay Camera Lister? Every time I open it I need to enlarge the window to be able to scroll to the bottom of the list. I can’t seem to locate any maxscript for the lister other than the VRayUtils.ms file that doesn’t really have relevant sections?
the thing is, that the lister has been written in c++ as I also learned over here, while having a maybe similar problem over here:
I suspected that might be the case given how the VrayUtils was written. Thanks for the info.
