Change format on cloned job
Is it possible to change output file ext when cloning a job?
When I render as VRimge and download I can get the correct display to show how it should be.
LOcally all is fine in the cloud I can see it’s looking the same but the VFB when opening the cloud render give different look. most odd
So I dont want to upload again if i can change the format in the cloud.
Cheers
Hi @stezza ,
I understand your point. Your suggestions makes sense and we’ll consider it. Unfortunately currently there’s no option to change the output image file type.
Thanks,
Vladie
Hi @stezza ,
On a second thought this (the unexpected look of the output image) might be a bug happening somewhere along the way from the 3D host app (V-Ray, respectively) to Chaos Cloud. Can you please share a Chaos Cloud job ID with me so we can investigate further? You can do so in a direct message to me if it’s more convenient. Also please share what is unexpected in the image.
Thanks!
Vladie
