Change Lights intensity
Am I supposed to be able to change the intensity of rhino lights in enscape?
Im trying the slider in the object property/lights menue but nothing happens.
The slider should work. If you have auto exposure enabled, and only a single light source, you won’t see any effect though, because the exposure compensates the light source intensity.
Still no effect when turning of autoexposure..
just to make sure Im not missing a step, this is what Im using
Maybe you need to switch to Rhino as render engine and so you should see the Rhino light control and not the Vray UI. It could be that the Vray light slider isn’t connected to the Rhino lights (used by Enscape).
Micha, thank you! That solved it!
I am having another issue
The enscape window and the exported image shows different light intensity, as shown in the image.
Is this expected or anything manageable in the setup?
Lights are emissive materials, does it make a difference?
@jpedstrand we’re aware of this behavior and this will be resolved as soon as possible.
