Change log of version 2.2?
I am wondering if there is a change log specifying what are the new features and bug fixes from 2.00.04. Looking at the files in the downloaded zip file, I couldn’t find a change log.
Also, will there be some videos showing what are new as the ones for Max?
Thanks,
Jason
If you install the new version, then you can find the new features and bug fixes from 2.00.04.
Please just check below path for the change log.
C:\Program Files\Chaos Group\V-Ray\Maya 20** for x64\docs\vray4maya_changelog.txt
I hope it helps you. :slight_smile:
Best Regards,
Sangho Jung.
Thanks a lot, Sersia. I will check that once I installed the new ver. Am I able to keep the 2.00.04 as my current scene is set up correctly with the old ver. and rendered stable. I don’t want to mess that up just because I install the new ver. for test drive.
