I’ve been using Enscape for Archicad (Mac) for 14 days but there is a feature I didn’t tested:
When you modify a material with the Enscape material editor it modifies the material inside archicad, at least the texture. But when you are using materials from an Archicad BimCloud library does the material change too when you edit in the Enscape material editor?
If the material is modified in the BimCloud library I suppose when you open another project the materials would automatically change and when start Enscape there’s no need to change them. There is a feature called batch import that I don’t know if it works combined with a Archicad BimCloud library
