Hi, we are with Maya 2022 and vray 6.1. Now its no longer possible to change min shading rate through render setting tab. We dont know why this option has been blocked. As we export to vrscene we actually see that the parameter is still there but we do not haave any change to control under maya ui.
Is there any way to do by Mel or getting all vray settings in the editor atributte to change this parameter manually.
Thank you.
The setting is accessible, however, we’ve hid it from the UI because we do not recommend changing the default value. What’s the reason for the change? Otherwise, an easy way to access it is to find the vraySettings node in the Outliner (disable displaying DAG objects only) and edit it there.
Hi Aleksandar, thank you for the reply. We will tweak from the outliner, no problem about that, we didn’t know how to reach them. We need to play with this value for some certain type of indoor scenes where we do not have motion blur, depth of field and the main light source is secondary rays. For that particular type of scenes raising up this value with other changes in the render specs lower down time renders.
