Changeing Vray fabric colours?
Hello, I am attaching a pic of a rendering I am working on. Very new to Vray and wondering if and how I can change a colour of a fabric? Can I use a colour with specific RGB value?
Any help would be greatly appreciated!
thank you
Jay
You could use V-Ray’s procedural texture - Color Correction - where you would slot the Bitmap texture and make the necessary adjustments. For more detailed information, please visit Chaos Docs
Thank you Georgi, but not real sure what you mean? This is the part I don’t really understand?
To color-correct a specific texture using a Color Correction, simply right-click on the texture slot to bring up its context menu select Wrap In and choose Color Correction. This will place the existing texture within a Color Correction and then plug it in the original slot.
Not sure what they mean by “This will place the existing texture within a Color Correction and then plug it in the original slot.”
Can I manually change the RGB value to get a exact color??
Thank you!!
Jay
The Wrap In option is when the Bitmap texture is already slotted in the Diffuse parameter (or any other). It is a convenient way to quickly wrap it in the Color Correction procedural texture.
Otherwise, you could start from scratch. Create a new material, slot the Color Correction texture in the Diffuse parameter, and then slot the Bitmap in the Color / Input parameter of the CC texture.
Regarding the RGB values, this would not be possible with the Color Correction. However, please be informed that the Color Gain parameter (Bitmap > Color Manipulation) could be used in this case
