I couldn’t find an option to change the color of the sofas or pillows on chaos cosmos?
And I couldn’t select the material using the sample paint tool in sketchup so that I could change it in the Material Asset Editor.
If there’s an option to change the color, that would be simply AWESOME!
I wanted to adjust the fall off map settings for the sofa since it seemed a bit too intense as shown below. But I couldn’t find any option
Hi @manishpaul_simon
Editing the materials of Chaos Cosmos assets is possible only after you Merge the asset. This action will convert it to a proxy mesh with materials - you will then be able to change them (or replace them completely); see example.
