changing file server
I am planning to change my server for maps
hard drive path everything will be same except server name
\\server2\maps\… to \\server3\maps\
is there any quick/script way to strip server name from all maps and replace with the new one instead of going one by one remapping
in max utilities use bitmap/photometric pathes
it does take a while in big scenes.
it doesn’t help, I have to go almost one by one with bitmap/path editor..
after maps folder there are stones, tiles wood, categories.. I just need to strip the server name and put the new server name,
under the file menu go to “Asset Tracking” , goto “table view” select all the bitmaps mapped to the old server then select “retarget common paths” then just change to the new server name.
asset tracker is by far the best tool built into max.
Thank you , retarget comman path did the job.
