Is it possible to change the size of foam and splash after they’ve been simulated? I did let Phoenix automatically generate the shader (PHXFoam001) for example, and I do see “Size multiplier ¶” in there. Would changing this value increase the foam size and doesn’t require re-simulating?
ALSO, I’m a little confused about the “resimulation” tab that’s new under my PhoenixFD001. Do I use this if I’ve already simulated and just made a few changes to my Dynamics, Liquids, etc.? If so, do I only need to tick “Particle Resimulation” or “Grid Resimulation” Enable buttons?
